2 Attachment(s)
Correlating injector data from spreadsheet to EFILive injector tables
Hello,
Got a project truck and I'm looking for the 'end all' injector thread where people share information on how to get aftermarket injectors properly implemented......it doesn't exist.
I've got Siemens Mototron 80lb injectors. I have the datasheets that were supplied with them.
I have (i think) successfully done the IFR table based on the spreadsheet here.
I also have properly (i think) setup table B4002 and used the linear fill function in between areas that weren't defined in the datasheet. For the 15VDC+ values, I simply adjusted by .004. I'm not worried about the 4.5 5 or 5.5vdc tables or should I be? Battery would be too dead to start the engine anyway... I treated each 'setpoint' as a linear equation.
What other data from the attached datasheets needs to be successfully entered into EFILive before I roll this out?
I've already done COS upgrade for 2 bar support, but haven't installed the 2 bar MAP yet so it's still scaled for 1 bar. Vehicle starts/runs/drives OK but before any serious tuning I would like to get the 80s in there and tuned. I want to take it 1 step at a time.
Thanks in advance
