Recalculate Timing Correction Table / Multipliers
Hey, just wondering how you guys are recalculating your main injection correction tables?
I made a calculator that compensates the correction tables according to the amount of base timing that has been added compared to stock. I do the recalculation at the max multiplier value (0.6) and then compare stock and modified side by side at different multiplier values and make modifications. So, when looking at base timing + effect of correction table at multiplier value 0.6 the stock and modified tables create the same timing. When comparing them at 0.25 or 0.4 they obviously do not match up so I play with the modified correction table until I find the happy medium between stock values and the modified correction table combined with the multiplier values.
