Need the opinion of others ;)
OK. So this is really getting on my nerves and I want to get the input of some of you other guys...
My dilemma is basically the large range in the BEN factors in some of my low MAP (decel) cells. For example the 1600 RPM vs. 20-25 kPa MAP ranges. Looking at one log the MIN value in this range is 0.88 and the MAX in that same cell is 1.21. Now as I calculate it that is a variance of 33%.
Is this what some of you are also seeing? Do you think there is a solution to it (changes to Throttle Cracker/Follower airflow for example)? Or is it just a case of "it's decel - give it up already"?
Would appreciate your experiences/opinions.
