Tuning a TBSS tonight, and the truck would shut down. Checking the Fuel Pump relay, I find that the trigger from the computer is only giving 5.7 volts.
Haven't checked the wiring yet, but anyone seen this, or could the ecu be bad?
Check your grounds on the driver side firewall and anywhere else on the vehicle. I am almost positive the trigger for the fuel pump relay from the pcm should be ground not positive.
Was the blazer acting up before you started tuning?
Are you getting 12v at all of the pcm and ign fuses when you are only getting 5 at the relay? If not check the ign switch out. If you are seeing 12v back probe the fuel pump relay signal at the pcm and preferably the 12v wire that feeds that part of the pcm. I'm on my phone so you will have to search for a pinout and diagram.
