I get a error while installing the drivers. I've had it running on this laptop before. got a virus and formatted the HD and reinstalled windows and now I cant get this to work.
Attachment 17814
Attachment 17814
Go Start->All Programs->EFILive->V8->Driver Manager
Edit: it should actually read like this:
Go Start->All Programs->EFILive->V8->EFILive USB Manager
and click the button to install the older FTI USB driver.
I get the same error message when trying to install for the first time on my laptop running Windows 7 Pro 64 bit. I tried V7.5 and V8 and both will not install the driver. I tried to manually uninstall the driver but that did not work either. I tried what you said above but there is no driver manager under the V8 or V7.5 folder. Please help!
It is called: EFILive USB Manager
Have you tried it...?
Also, are you logged in as Admin when you install...?
i tried that joe. no go. I just got a message that my windows ins't genuine. curious if thats the reason.........I went and brought a mac book, pararells, and windows 8.1 and drivers loaded and can see my cable also. My windows machine also willn't load my hptuners drivers either
Sounds like there is a problem with your Windows OS install... did you register it with a proper unused Windows key...?
Hi,
I have the same issue here....
