LQ4 swap lost communication, spark, and fuel.
Hey guys, I don't post much but I am on here quite a bit. I have done a LQ4 swap into a 74 GMC. Tuned with EFI Live. I was trying to read the gauges with my laptop but was not able to connect. I tried my scan tool with the same issue. No communication. I started it 6 more times since then and now I have also lost spark. Now my fuel pump only comes on for a split second when I turn on the key. I've bypassed my pump wiring to make sure the pump still works. The pump turned out fine. I have checked my grounds and added extra ground wires just to be extra sure it is not a ground problem. Double checked my battery positive terminals to the data link connector and PCM. Everything checks out fine. But still no communication to a scan tool and no spark. Could I have a bad PCM? If so, what would have caused it? If I am to switch PCM's, is there a PCM with an operating system I should be looking for? Anyone else have any ideas? I appreciate any help.
