when will we be able to use them? I have a coupe trucks it'd be really handy to check them on
They used to work. Something has changed along the way.
Which ECM type?
I can't seem to get them to work on any Duramax or Cummins ECM Ross.
I had specific PID files setup for 2001-2010 Dmax and 2006-2009 Cummins. They used to work fine last year. Somewhere along the way something has changed.
Currently have an LB7 here that just just shows zeros for the balance rates when connected and logging. Scanner acts as though its logging properly but no data is displayed.
Can anyone else please confirm if they have stopped working on all Diesel platforms?
I don't know what changed between when I posted last night and this morning in regards to this LB7. But they are now functioning.
Not working on 2300 ecm 13 ram works on my 06 have latest public release .
I am pretty sure they've never worked on 2010+ Cummins (earlier years, yes), each ECM type for Cummins has different data streams and I don't recall setting them up but that would not have been because we couldn't be bothered, they may have changed the reporting strategy on them and we decided to leave it for another day.
Ok just checking see if there was a problem 1st time pluging into my 13 to check injectors having issue. Thanks
