Quick question for you guys. I have had my RR for a while and usually I just use a single wideband to tune. Well, working on a TT 5.3 and the owner installed 2 widebands. I noticed that the first wide band was acting flaky so I wanted to switch to the second. No matter what I do I can not get the second channel to work with the RR. It works fine in the scanner and I can log all day with it, I was logging both channels the entire time.
[LS1]
;Main VE Table
B0101.ROW=SAE.RPM
B0101.COL=SAE.MAP
B0101.RRR=CALC.BEN_LC11,CALC.BEN_LC12
Thats the setup I have right now. WHen I would try and use CALC.BEN_LC12 I could not get the RR to work with it. I even tried this.
[LS1]
;Main VE Table
B0101.ROW=SAE.RPM
B0101.COL=SAE.MAP
B0101.RRR=CALC.BEN_LC12
Still nothing. I had to physically move the #2 WB to the #1 input to use it with the RR.
Am I missing something here?
