Desired Fuel
There are two tables (A9101 and A9102) that determine desired fuel given a certain throttle pedal position. One is Normal and one is Transient. Can someone tell when each is used. They both are identical. I suspect that if you want to eliminate smoke, these are the tables to tune/modify but it would be nice to know which is being used when.
You'll need to mod more than those two tables to control smoke properly.
Transient throttle is when the throttle is changing positions. Generally it is used to increase or decrease fueling response to pedal movement.
apparently modifying them has no effect. At least not according to my log
