Known issues with the November 2015 Public Stable-Release
Currently known issues and possible workarounds for the November 2015 Public Stable-Release of the EFILive Software and Firmware
Download the public stable-release EFILive software here: http://www.efilive.com/latest/cat/download-efilive
Public pre-release software versions:
- Software: V7.5.7.298
- Software: V8.2.2.289
- FlashScan/AutoCal firmware: V2.07.94
Issue 1:
Workaround:
None.
It is a restriction of the *.efi (V7.5 log file format). That restriction will be removed and the TCM PIDs will display their true origin once the V8 scan tool software is available.
Issue 2:
The V7 Scan Tool menu option "Edit->Copy for export to V8" copies the currently selected PID list to the clipboard in the wrong format for V8. That means it cannot be pasted directly into either the V8 Scan Tool PID selection or the V8 BBX PID selection.
Workaround:
Paste the copied/exported PID list into Notepad (or any similar text editor), then remove the leading dot from each PID entry. Copy the updated PID list back to the clipboard, then paste into V8.
Issue 3:
Sometimes, after updating the AutoCal/FlashScan firmware, the "Rebooting" message and green progress bar remain visible on the screen even after FlashScan/AutoCal has finished rebooting.
Workaround:
Close down and restart any running EFILive V8 software.
