I've looked over and over cant find what I'm doing wrong every time I try vet table log strange numbers like .1-.6 anyone have any ideas TIA
Post your:
- calc_pid.txt
- tune file
- log file
and some pics of your map.
hope that worked
Your EXT.WO2LAM1 pid is pegged at 1.7... your wideband is not working.
wow im sorry was so sure i did something wrong i didnt even look at that had the blinky light on v2 thought all was grand
wo2 seems to be working but still giving me same numbers and it was working in other logs as well i must have sent one it wasn't is possible i need to configure them differently i'm using inovate lm2 (which apparently i could have used a much cheaper version and got same result maybe less confusing)
Ok, it looks like wideband is now working... it shows lean on throttle close, maybe turn off DFCO during tuning.
Post screenshots of:
- your MAF map (SELBEN vs MAFFREQ Hz),
- your VE map (VET g*K/kPa vs MAP kPa vs RPM).
You don't have enough data, you need to drive around for about 20-30 mins, use steady /progressive throttle, don't jerk the throttle.
BTW: when throttle opens significantly, you get bare any PE...
check this:
- B3616: set to 65% below 3200 rpm, 35% above 3200 rpm.
- B3609, B3610: set both to 0.020 seconds.
- B3613: make sure this is less than 100 kPa (set it to either 50 kPa or 70 kPa).
- B3618: set this to EQR 1.175.
