May 2016: EFILive Beta 3 Test Release
Please download and install both the V7.5 and V8 software packages.
Both the V7.5 and V8 software were updated in this beta test release, you must update both software packages.
ATTENTION - BETA SOFTWARE RELEASE
At EFILive we have changed the way beta testing is conducted. The EFILive beta software is now available to all users. We strongly recommend that you do not install the beta software over the top of your production systems. It is possible that the beta test software may fail and your production system may not be recoverable. lf you conduct a tuning business, please take the necessary precautions to protect your business. EFlLive recommends beta testers use a separate FlashScan V2 device (when installing the latest beta firmware) and only install the EFlLive beta test software on a separate PC, laptop or virtual machine.
Release Notes:
Version Numbers:
After installing this beta release you should have the following software, boot block, firmware versions installed:
EFILive V7 software: V7.5.7 Build 306
To view the installed version, select Help->About (in the V7 Scan or Tune software).
EFILive V8 software: V8.2.2 Build 297
To view the installed version, select Help->About (in the V8 Scan and Tune software).
Boot Block: V2.07.007 (Feb 07, 2014)
To view/update the Boot Block, click the [Check Firmware] button in the V8 Scan and Tune software.
Firmware: V2.07.100 (May 10, 2015)
To view/update the Firmware, click the [Check Firmware] button in the V8 Scan and Tune software.
Known Issues
Issue 1:
Workaround:
None.
It is a restriction of the *.efi (V7.5 log file format). That restriction will be removed and the TCM PIDs will display their true origin once the V8 scan tool software is available and fully integrated with the V8 tuning tool software.
Issue 2:
When logging DMA PIDs (i.e. PIDs whose names end with "_M" or "_DMA"), if the ignition is switched off for an extended period while data logging but data logging is not terminated, then when the ignition is switched on again the data log automatically continues. However the DMA PIDs may no longer return valid data.
Workaround:
EFILive recommends stopping the data log and restarting the data log when switching off the ignition for extended periods.
