Hi Guys, Can i use my V2 as a gauge to view the wide band when powered up but not connected to a ECU (wide band is connected via serial) basically use it as a gauge?
Cheers Mike
Cheers Mike
The serial comm interface works with just a USB connection, no OBDII connection required.
The orange analog inputs require 12V via the OBDII connector to function.
Thanks, so if i have it powered with USB and go to Display W02 it should show up? (wide band connected and powered up as usual)
That's what i thought..all i get is "WO2 not found" I am betting i haven't got something right. any suggestions?
Yes wide band powered up. I went through it again as you have listed ( I had it correct) and it still shows not found
