L99 Camaro 2010 A6 Engine Tuning
Looking for a little help. I have a 2010 Camaro I installed long tube headers and full exhaust and K&N Intake system. I purchased and also installed a
LC-2 Inno WB AFR and Gauge. I still need to get a USB to Serial Adapter to hook it up into my laptop. So to get started I Disabled STFT,LTFT, Engine in OL, Disabled DFCO Failed the MAF and Removed the Yellow Wire. I commanded AFR to 14:3.1 and 12:5.1 For PE. The car runs like Sh!t with this setup so I reinstalled the yellow wire and have it set like that. I cleared my Fuel Trims as well. Can you tune the VVE table on an L99? I did the fuse pull as well for high octane (93). Also my wideband fluctuates a lot on the guage...doesn't seem normal to me.
Also how do I hook up the LC-2 to read in EFI scan tool? Can someone here maybe point me in the right direction. thanks.
