Table (B9120) has all 1's, is this table active or turned off elsewhere with reference to table (B0909)?
Thanks,
Michael
Thanks,
Michael
B9127 references maximum #2 of 5 mm3 stock. B0909 is active with 1 mm
I'm not sure why this posted weird. B9127 references #2 pilot at Max of 5 mm3. B9120 is active with a minimum of 1 mm3. As pilot 3 is active b9130 at 0 mm3 and a Max of b9137 5 mm3. We don't have a pulse table to play with that these reference to.
Sent from my 2PS64 using Tapatalk
If pilot #2 is active, meaning both pilot #1 and #2 are active, would timing base C be the table used?
Or does "active" mean actively pulsing and I'm using Timing base B because there is no activity on pilot #2?
What is keeping Pilot #2 from pulsing?
b0909 Timing base B:
This is the base start of injection (injection timing) table with just Pilot 1 active, this table is based on fuel delivery per stroke (mm3) and RPM.
This table is used most of the time during normal running.
B0910 Timing base C:
This is the base start of injection (injection timing) table with both Pilot 1 active & Pilot 2 active, this table is based on fuel delivery per stroke (mm3) and RPM.
Michael.
Just my 2 cents worth, but in logging, I've never found any set of circumstances for which pilot 2 or 3 becomes active. Has anyone else?
[QUOTE=VegasDMAX;245453]Just my 2 cents worth, but in logging, I've never found any set of circumstances for which pilot 2 or 3 becomes active. Has anyone else?[/QUOTE
I have not, but only have about 10 hours logged.
