Hello,
Assuming Efilive won't allow to do any deletes with the HD version? I am in Canada and Emissions are not required here.
It would not be hard to make the ability to delete emissions location based.
Hello,
The parameters are not even in the software, I wouldn't know where to start if we wanted to do it. I understand what you are saying about location based but it's just easier to play by the rules when your #1 market is the USA.
Fair enough
Does the support extend to the CM2150D models?
Yes the CM2150 is supported (D & E versions), but same as the original post there is no emission removal parameters for those ECM's either.
No there isn't sorry, file formats between both tools are not compatible.
However EFILive can convert Calterm Xcal files to use in EFILive, there is a program we include with the software to do this.
