Making dual electric fans work without having to segment swap
Looking for some help to verify that I can make dual electric fans work on a vehicle other than the Camaro / Corvette (e.g. - not having to do a system segment swap). I have gone through the code in a 2001 disassembly and think that I found out why the regular EFILive parameters won't allow it. There is another parameter that pertains to the 2nd fan which is not currently in the EFILive. I created a CAX file for this additional parameter that seems to make it work. I have checked in on my bench 0411 using a 2002 OS, but would like to have someone else verify it on an actual vehicle. If you are willing to give it a try please let me know (FWIW - I am pretty sure I can find the correct parameter in any 512 kB OS).
