As the title says A/D inputs in all variants of V8 scanner showing 0v while FlashScan V2 shows voltage from the A/D inputs. V7.5 scanner works as expected showing voltage the same as the FlashScan V2. Switch back to V8 scanner and A/D inputs show 0v. Is there a setting or adjustment needed for the A/D inputs in V8 scanner to show the voltage in the FlashScan V2?
Thanks Jon
