2018 truck won’t allow cruise over 85 even with parameter maxed out.
OS 32180100 converted to csp4.
This fixable or will I need to try a diff OS?
[QUOTE=TWITCH02X;253916]2018 truck won
Thanks smokinpete379... Ive tried several things to get CAX file to open along side my ctz in v7.. Changed the file name to 52180100 since I had already converted to csp. tried leaving as 32180100, changed the segment to 2, changed major folder to CAX..
Do the CAX files need to have all the default description stuff like the TEMPLATE file??
Not having much luck..
You put the cax in C:\Program Files (x86)\EFILive\V7.5\Calibrations?
If you leave the cax named as the stock OS and open your stock file does it display the cax parameter?
Yes, putting file in C:\Program Files (x86)\EFILive\V7.5\Calibrations.... Same folder the Template is located.
Just tried with unconverted file & same thing... I will try making a few more changes to the CAX & see what I come up with... Will report back later..
Are you running the latest version of Efi? I opened stock file with that cax and it displays perfectly.
https://uploads.tapatalk-cdn.com/202...e2ad9fd975.jpg
Sent from my iPhone using Tapatalk
I have it set so your v2 or v3 must be plugged in for it to be visible. Maybe that
I think you want to change it to 1.
Yes, that
2 worked
