Quote:
Originally Posted by MN C5
From what I can gather enhanced features (Changing the PCM Code) are available from a couple of vendors that use EFI FlashScan on top of changing the PCM Code.
For about 1200 american it looks like you could get a 2bar tune from ChipMaster add that to purchasing EFI Flashscan and your at about TWO THOUSAND american dollars.
Not sure if its worth that, because you could just install the 2bar using the table values as half from a kpa standpoint.
That or MegaSquirt may be the best way to go IMHO.
I run Chipmaster and the tune we offer is a full custom 2 bar tune that was developed in conjunction with Ross (GMPX) a few years ago , It has already been hinted on how we do it presently ( we also change some stuff in the code for dual spark and some other features ) but it can be doe at present with the tools you have available.
A full 2 bar program and other speed density stuff is being developed for release to flashscan customers as a base starting point in the future but other things are taking priority at present but it will happen - rome wasnt built in a day
