I can save the calc_pids file with ONLY the MPG PID and Scan Tool works fine but, when I try to merge the two I get the error "Units MPG not found."
Wondering if you can tell what I'm doing wrong.
In the attachments... I changed file names to help explain the issue:
calc_pids.txt is the original file
MPG calc_pids.txt is the pid I am trying to merge with the original.
calc_pids modified with MPG.txt is the merged file that gives an error.
