Can anyone help, I was wondering what I would need to convert my 1969 Windsor Carburetor powered engine to lap top tuning?
I know I need to convert to EFI but what else would I need, thank you
To convert your '69 Windsor from carb to laptop tuning, you'll need: an EFI intake manifold, fuel injectors, high-pressure fuel system (pump, regulator, return lines), a crank/cam position sensor setup, a compatible ECU (like Holley Terminator X, MS3, or FiTech), wiring harness, and wideband O2 sensor. After that, you can tune it via laptop. It's a solid upgrade if you're aiming for better drivability and control.
Prock1950,
I removed the spam url that you sneakily included in your quote do not repeat that mistake.
