4 Attachment(s)
2nd Gen Cruze Read shows incorrect info
As title states i have a 2017 chevy cruze with the 1.6l diesel and a 6speed manual trans and E98 ecm. When i read the ecm under controller calibrations it lists that its an automatic. Equipment used to read vehicle was a flash scan v2 and v8 software via obd port. I do not believe this car has ever been modified and when i compare to gm sps info everything seems to match up. Is this just a bug?
I have not licensed this controller yet and i have not attempted to flash it because I'm still trying to get everything figured out and teach myself what has to be done. Things have changed so much since i have done anything like this.
I am also having trouble finding the OEM file as well as definitions and addresses associated with that 24000207 os, should i use a different compatible os? the lookup utility list 6 other os's 3 are 554 and 3 are 555 which seems way off considering my os is a 240.
Any help would be appreciated or any guidance would be greatly appreciated.
