Proper way to raise part throttle shift points
I am trying to dial in a 2000 C5 A4 car that we just put 3.42 gears in. The guy had been complaining that the car was shifting too early at part throttle so I would like to stretch out the shift a bit.
It looks like maybe raising the D0901-D0903 MPH should make this happen but wanted to confirm that there are not other tables that tie into this.
I also notice it needs quite a bit of pedal to down shift and see that D0906 is noted as 100% TPS. I assume that lowering the TPS % will enable down shift earlier?? Sounds obvious but the tranny is as unique as the engine management!
Just looking to do it the right way.
Howard
