which are the best to use for auto tune sd and where to get them Thanks Bewbee Woody
There is a new PLX that can be used with a laptop for $200.
The PLX is not fancy, does not need to be calibrated and it just works.
so I can't just get wb o2 and put them in place of my old ones.
You can, but it is often considered, seldom done. You are probably better off with a separate bung for the WB sensor or use one of the rear bungs temporarily.Quote:
Originally Posted by woody69
The lc1 is in-expensive as well, but takes a bit to get set up right.
A spare bung for the WB is not a bad idea. I run open loop full time and installed my LC-1's in the primary (BxS1) locations.
My passenger-side NB O2 was dead, so I just put the WB O2 in instead ... no problem so far, works fine ...
I just recently welded my LC-1 bung into the I pipe where there's a nice notch in the floorpan giving great room for install. I had it in the PS header but wanted to get AF of both sides combined. The sensor threads stripped taking it out of the header so a new sensor is in store before checking the difference from header to I pipe.
BTW, if you need a replacement sensor and know someone with an account with NAPA, they are listing the 17014 Bosch sensor for 69.00 list and 42.00 cost for the shop I work at. After looking at Advance and Autozone for the same part I think NAPA has their pricing wrong so get em while you can. I ordered 3.
For those kind of prices, you may as well get a second controller so you can see what's going on in both banks
Just when reading one was enough to drive you nut! :)Quote:
Originally Posted by TAQuickness
Did someone post that they used a WB o2 in the rear position? After the cats? I have always wondered if this can be done with any accuracy as the cats remove raw hydrocarbons not air. Many times I pull of the tail pipe to baseline a car prior to mods and it seems pretty accurate thus far. Any thoughts on this?
Howard
I think pre or post cat comes down to splitting hairs, as many folks get similar results either way. My preference is pre-cat as it eliminates the cat as a potential variable.
