I was wondering if there was a way to prevent the check engine light from illuminating with EFILive (due to aftermaket exhaust or intake). Maybe to modify the parameters it has to see before it sets a code. Which table is this?
Yes, Engine Diagnostics, MIL Enabler and DTCs.
That will turn codes on/off or stop the Light from turning on.Quote:
Originally Posted by Doc
I don't think we are able to change the condition in which sets the code.
eg make the parameters broader in which it sets a code (desensitise)
You can change the condition(s) in so far as how many ignition/trip cylces are required for the code to set.
Very cool ! Thanks.
Wow wow! I'm not allowed into that! Do I need to upgrade my software???
I have 7.3 and an '06 LBZ, can't even get into " engine diagnostics" !!!
File->Select Contoller
FIle->Enter VIN
It does not have an option for select controller under "file"
(nor "enter VIN")
I tried entering the VIN on the right side but nothing changed.
I think I'm doing something wrong again.
Hmmm, this is in the scan tool:Eyecrazy:Quote:
Originally Posted by joecar
Oh... that's in beta 496_628_582... I think you have to update... showthread.php?t=4585
http://img410.imageshack.us/img410/5291/stlq6.png
