What else can I tune without scanning or black boxen it? Tune history inside.
Check out the below. Most of what has been done is Speedo correction, TQM stuff, and PE stuff. This if for an 01 5.3 Z71 RC. I am only running 93 octane now so I fugure there are a few more things I can do. The only thing slowing me down is no black box function from the V2.
Apr 25, 2007 21:59:06
Engine Calibration.Rev Limiter
{B3330} Fuel Cut-off in P/N, changed from "6000" to "6050".
{B3322} VSS Failed RPM Limit Upper, changed from "6000" to "6050".
{B3303} Fuel Cut-off Limiters in Gear, modified.
{B5401} ETC Controlled RPM Limit, modified.
Engine Calibration.Torque Limiting
{B1901} Max Allowed Engine Torque, changed from "350" to "500".
{B1902} Torque Loss from Spark Retard, modified.
Engine Calibration.Traction Control
{B6614} Max Torque By RPM, modified.
Transmission Calibration.Shift at VSS.Upshift
{D0910} WOT 1->2 Shift Speeds, Normal, changed from "36" to "40".
{D0911} WOT 1->2 Shift Speeds, Performance, changed from "33" to "45".
{D0912} WOT 1->2 Shift Speeds, Hot, changed from "33" to "36".
{D0913} Manual Hold Gear, 1st, 1->2 Shift Speeds, changed from "255" to "256".
{D0915} WOT 2->3 Shift Speeds, Normal, changed from "68" to "75".
{D0916} WOT 2->3 Shift Speeds, Performance, changed from "68" to "83".
{D0917} WOT 2->3 Shift Speeds, Hot, changed from "68" to "73".
{D0918} Manual Hold Gear, 1st, 2->3 Shift Speeds, changed from "255" to "256".
{D0919} Manual Hold Gear, 2nd, 2->3 Shift Speeds, changed from "255" to "256".
{D0920} WOT 3->4 Shift Speeds, Normal, changed from "255" to "256".
{D0921} WOT 3->4 Shift Speeds, Performance, changed from "255" to "256".
{D0922} WOT 3->4 Shift Speeds, Hot, changed from "255" to "256".
{D0901} Part throttle 1->2 Shift Speeds, modified.
{D0902} Part throttle 2->3 Shift Speeds, modified.
{D0903} Part throttle 3->4 Shift Speeds, modified.
{D0914} Manual Hold Gear, 2nd, 1->2 Shift Speeds, modified.
Transmission Calibration.Shift at VSS.Downshift
{D0925} WOT 2->1 Shift Speeds, Normal, changed from "31" to "33".
{D0926} WOT 2->1 Shift Speeds, Performance, changed from "35" to "38".
{D0927} WOT 2->1 Shift Speeds, Hot, changed from "31" to "33".
{D0928} Manual Downshift 2->1 Shift Speed, changed from "39" to "42".
{D0930} WOT 3->2 Shift Speeds, Normal, changed from "65" to "70".
{D0931} WOT 3->2 Shift Speeds, Performance, changed from "67" to "72".
{D0932} WOT 3->2 Shift Speeds, Hot, changed from "65" to "70".
{D0933} Manual Downshift Gear 3->2 Shift Speeds, changed from "237" to "256".
{D0935} WOT 4->3 Shift Speeds, Normal, changed from "237" to "256".
{D0936} WOT 4->3 Shift Speeds, Performance, changed from "237" to "256".
{D0937} WOT 4->3 Shift Speeds, Hot, changed from "237" to "256".
{D0906} Part throttle 2->1 Shift Speeds, modified.
{D0907} Part throttle 3->2 Shift Speeds, modified.
{D0908} Part throttle 4->3 Shift Speeds, modified.
Transmission Calibration.Shift at RPM.Upshift
{D0940} WOT 1->2 Shift RPM, Normal, changed from "5600" to "5750".
{D0941} WOT 1->2 Shift RPM, Performance, changed from "5200" to "5950".
{D0945} WOT 2->3 Shift RPM, Normal, changed from "5200" to "5750".
{D0946} WOT 2->3 Shift RPM, Performance, changed from "5200" to "5950".
Transmission Calibration.Desired Shift Times
{D1108} Desired 1-2 Shift Times, modified.
{D1109} Desired 2-3 Shift Times, modified.
{D1110} Desired 3-4 Shift Times, modified.
Transmission Calibration.TCC.Apply
{D1001} TCC Apply Speeds - Second Gear, modified.
{D1002} TCC Apply Speeds - Third Gear, modified.
{D1003} TCC Apply Speeds - Fourth Gear, modified.
Transmission Calibration.TCC.Release
{D1004} TCC Release Speeds - Second Gear, modified.
{D1005} TCC Release Speeds - Third Gear, modified.
{D1006} TCC Release Speeds - Fourth Gear, modified.
{D1008} TCC Throttle Release - Third Gear, modified.
{D1009} TCC Throttle Release - Fourth Gear, modified.
Transmission Calibration.Trans Pressures
{D0701} Base Pressure 1->2 Shift, modified.
{D0702} Base Pressure 2->3 Shift, modified.
{D0703} Base Pressure 3->4 Shift, modified.
Transmission Calibration.Torque Reduction.Upshift
{D0801} Torque Reduction 1->2 Shift, modified.
{D0802} Torque Reduction 2->3 Shift, modified.
Transmission Calibration.Torque Reduction.Abuse
{D2003} Abuse Mode Speed Enable, changed from "255" to "256".
{D0301} Transmission Torque Reduction, changed from "Enable" to "Disable".
Speedometer
{H0101} Vehicle Speed Sensor Pulses per Mile, changed from "97578" to "90400".
{H0104} Trans Output Shaft Revs/Mile, changed from "2537.9883" to "2260.0101".
__________________________________________________ ______________________________
Apr 26, 2007 17:58:29
Engine Calibration.Fuel.Mixture
{B3610} PE Delay RPM Bypass, changed from "5500" to "0".
{B3609} PE Delay Counter Adjustment, modified.
Engine Calibration.Spark.Knock
{B6210} Burst Knock Delta Air Mass, modified.
{B6212} Burst Knock Retard, modified.
Apr 26, 2007 20:44:48
{B3616} Normal PE Mode Enable, modified.
Apr 26, 2007 21:04:08
{B3618} PE Modifier Based on RPM, modified. Curved but around 12.2
{B3616} Normal PE Mode Enable, modified. Forgot but maybe around %65
Apr 26, 2007 21:08:18
Transmission Calibration.TCC.Pressure
{D2902} TCC Maximum Pressure, changed from "120.0" to "140.0".
