Is there a part number for this. Mine broke while prying it from the connector. Any help would be great!
Can you post a pic, or more details?
Its the teal colored plastic piece. It's U shaped. I'll call the dealer on tuesday.
I got a little aggressive while trying to pry it out to install the DSP5 switch and broke the end off. The two legs are still in the connector so the pins should be fine, I just want to have a new one so everything is stock appearing.
PCM Connector C1 12191489, this is my best guess for the part number. Good luck,
AL
thanks Al!
