As it asks. Which PID's need to be selected for the different power PID's to work. ie: HP to wheels, engine tq, ect..
go to calculated pids and you can get power at wheels
power_rw
or click on performance and they are there
system= performance to get pids
I Understand where to get the PID I am just not sure which corrosponding ones I need to get them to work properly on the dashboard.
does yours have an x across the pid
No but if I right click on certain power PID's the the info tab isn't highlighted and others I get an error.
example.
http://img.photobucket.com/albums/v6...rearwheels.jpg
click on delivered engine torque and then power at flywheel will work ,
Ok..got that. Do you see where the box on the link above states
PID Value cannot be determined because
the following error would occur:
Divide by zero.
That doesn't allow any reading when I log. It always reads zero for HP at wheels
Just found it. Have to select Wheel acceleration/deceleration PID to make it valid. Thanks for helping out.
yeah i seen that i don't think it can calculate at wheels without having something else, like maybe four chanel abs or something, not sure on that one
