Obviously you can re-arrange the order in which PID appear by changing the option.ini file.
Can you add pid which aren't already present?
There is a folder on your PC (If you are beta testing the BBLogging) that has text files for the different controllers. Find the one you are working with and it has all the available PID's for BBlogging at this point. There will be more when the beta testing is complete.
C:\Program Files\EFILive\V8\EFILive_Hapi\Pid Descriptions
Ok. I will investigate that. Thank you. So custom PIDS can't be loaded.
