Custom Gauge?
OK so I can't make the GM.BARO2 PID work on my 06 LBZ which is half of the equation for the CALC.ACTBOOST gauge in the vdash. So i was thinking about a work around. GM.BARO works but is only in inMg and kPa not PSI and BOST2.DMA works and is also in kPa. So is there a way to create a custom gauge with custom math to re-create the CALC.ACTBOOST without having GM.BARO2 with the previously mentioned PID's?
I think this question was also posted over at Diesel Place?
I forgot to put the maths in to allow imperial, sorry about that. Will be fixed for the next software update which hopefully will be out in a couple of weeks.
I made a calc.pid as a work around.
Thanx,
Justin
