where is every one finding the switches they are using for the dsp5. i though i could find it here i give lol so funny so much info but some how i miss the little stuff. unless evey one goes to radio shack and buys 5 resistors and wires it all up ?
thanks i went there didn't see it befor
Scroll to the bottom of the page.
found it thanks
Also The newest V2 update controls the new switching system that allows you to not have to run a switch anymore. The V2 unit itself will be the switch. You just plug it in the dash and press change tune and it flips to another program instantly on the fly. The customer would just need a V2 unit. Scan only or tune will both work as long as it is a v2.
is that out now
No, will probably be in Beta by next week.
So why would this be easer to use then a stationary switch.
You dont have to run any wires at all, no cutting holes in the dash to plant a switch, no pulling connectors apart and putting them back together. When you want to change a tune you just press one button on the v2.. Simple.
