Touching up VE table using BEN/AutoVE
Hi All,
Now that I have the PLX hooked up through the serial input on the V2, I have discovered my commanded AFR vs. actuals are quite a bit out... I would like to touch up the VE table to fix this up before a track day (in a couple of days :)).
The tune (COS3 OLSD) was done by someone else (paid), so I dont want to start again.
My question is, do I have to go through the AutoVE tutorial and load the AutoVE cal in that it creates, or can I use the calibration already in there and just change the following:
*Disable DFCO
*change everything in b3467 that is currently 1.0000 to 1.0049 (14.63 to 14.7, stoich (b3601) is set to 14.63)
Is there anything else that needs to be done? Do I need to disable PE?
My appologies if its a stupid question, just trying to get my head around it...:shock: :help2:
