2 Attachment(s)
the injector flow rate table..
I was noticing that when I put in some exact numbers into this table from an excel sheet (injector flow rate calculator sheet) and I saved the tune in EFI LIVE and then exited and came back and brought up the injector flow rate table (B4001) that the numbers were a little different from what I had put in.?? a little weird to me.
I noticed that when i used 53.5 psi and i saved and came back that EFI LIVE lowered the numbers compared to what I put in. Then I used 54psi and saved and reopened the file and it gave me higher numbers than what I put in.
just . this is my injector flow rate calc
