:help:
Does EFILive support SIR testing, and/or clearing codes?
Anyone care to PM me the mode and/or message to clear the BCM or SIR DTCs and I'll do it myself with my usbcan cable even?
:help:
In the scantool there are options for reading/clearing DTC's from all modules...
See under Edit->Properties->Advanced.
Clear trouble codes from modules listed on [Modules] tab page.
Is not implemented in E67 Controller.
Also the modules listed are only the ECU and TCU.
I tried both the V2 DTC clear and FlashScan DTC clear neither fixed the problem.
I'm using V7.5 and latest beta BBL too.
Oh SNAP Solved! I actually followed the disable procedure for the SIR system and it cleared the DTC.
It's basically remove the Airbag fuse(s) and turn on the ignition to verify it's disabled. Disconnect the negative battery and wait 1 minute before working the SIR system. Then replace the fuse(s) and reconnect the negative battery cable.
