Easy efi live / lc-1 wireing Question
What wire should connect to the middle EFI "pin out"? I have the yellow to the exterior of the tri terminal (the instructions said it didn't matter which one), but the instructions call for a "Signal Ground" to the center terminal. Further it clairifies the white and green.
Bottom line:
To what LC 1 wire do I connect to the EFI Live v1middle "pin out"? (if any)
Now I dont have a green, but I do have a blue and white. the EFI live instructions say to connect the blue system ground seperate from the signal ground. But the blue is the heater ground and the Innovate say to ground the white and blue together. Should I put all the ground together? Does it matter if the calibration wire is grounded to the same ground bus?
THanks!
