setting rev imiter for racing?
Is it possable to set the limiter so when I'm staged I can just floor the throttle and hit the limiter at 4500rpm but whne I release the clutch the engine can rev to 6500rpm?
I know there is a limiter that does this independantly but can it be done buy efilive through the cars pcm?
Re: setting rev imiter for racing?
In our latest release of custom O.S upgrades we have a user selectable rev limiter, you can wire up a switch to enable a lower rev limiter when the switch is closed. I guess it could be mounted on the steering wheel?.
Problem with doing it off the clutch switch is it will do it everytime the clutch is pressed. I am not sure how sensitive or how much travel the clutch can have before the switch is pressed, but it may switch to the lower rev limit just as you shift 2 - 3.
At least with a seperate switch once it is opened (as you leave the line / dump the clutch) then it cannot come back on as you shift gears.
