2 Attachment(s)
AutoVE verification file & PID log questions
This is a continuation of the discussion within the "How to adj AFR @ WOT thread.
Ran the verification tune & log this evening. MAP values are all 0.00. I think this means that the VE mod was successful, somewhat. The LTFT's are not good & are commanding up to the max. +25%. There are also three red MAP cells. There is no AFR log because I didn't see the connection issue from the PID to the PLX controller until the car & computer were ready to drive. Looked as though the PLX (wide band) diplay was the same to a bit more lean than commanded, as I glanced a few times from the driver's seat. The LTFT is a mystery. What should be done? BTW, it was a short drive.
