my car will not start, it keeps cranking and seems to not be getting any spark.
it will start if i floor the gas peddle but it sputters and reeks of gas.:angel_innocent:
FP is fine (60PSI) while cranking, IBPW averages 30.6ms,
fuses are good, relays are clicking and battery voltage drops to 9volts:shock: with a new battery.
i was getting P1626 but it has not come back.
i am getting U1016 consistently.
i can scan/log and upload/download my RR but i can not retrieve the calibration/VIN with the tune.exe,
it says flashscan is not connected.
i thought it might be VATS because of the P1626 but, i logged GM.STATE02
and VATS Fuel Disable is Inactive.
i now suspect some kind of ground or connector wire has failed. (where?)
any suggestion is appreciated.
Attachment 3814
Attachment 3815
