Probably a stupid question but Do both USB plugs have to be in the lap top.The one from RR and the one from the V1 box?:confused:
NON RTACS MODE: (you manually start writes)
Correct, you do not need the ignition key on to read/write the RoadRunner. Its gets its read/write power source from the USB port, not vehicle.
RTACS MODE: (software automatically writes changes based on dlog)
1 USB for READING datalog from OBD2 port and external data such as widebands or other inputs.
1 USB for WRITING the RoadRunner
SCANNER ON AND RUNNING:
The only way RTACS mode will work is when the RR is in "REALTIME" editing mode (this is in the RR dialog box) and the datalogging is in RECORD mode (the little RED, no yellow button ) in the scanning software.
Example: You are going to real time update the VE table via RTACS. You would need at a minimum to log the x, y coordinates of the VE table in the datalog, SAE.RPM and SAE.MAP. RTACS interpolates which cell to update from that data. Also, make sure the units in the datalogger are the same as in the tune tool otherwise, it will not work right.
I have a software animator and will try and post up a real time example if EFI Live has no objection. I would suggest you get familiar w/the software for using RR/RTACS by first experimenting w/the engine off, key on. That way you can get a datalog and undo potentially harmful changes.
Well so far so good.Got the RR working,Tomorrow I will put it in the car and see how it works:grin:Thanks for the help :good:.........Paul
Where would the bluetooth plug into on the laptop? I have 2 USB ports,But I really need 3.One for the RR,One for EFILIve scan and one for my tracball mouse.My laptop mouse does not work.Would a single male USB plug with double female ends work for the tracball and scanner?..................Paul
In your case, the laptop would need to be equipped with bluetooth. If it isn't you would be better with the direct connection. I'm not sure on all the power requirements of the devices, but my RoadRunner likes the higher powered USB port.
Al
the RR does not tolerate sharing a USB port.
at least mine didn`t when i tried to plug it into a USB hub.
