Paul or Ross,
Any luck with the T42 cals. The base pressure oddity...
Paul or Ross,
Bueno.....:)
The pressure tables received an update and will be available in the next release - due this weekend.
Cool. Thank you sir:)
I tried the update, un-installed and installed with no luck...Pressure's on the 3-4 shift are still maxed out......@ 620kpa
Well, at this point I have to say I am lost! It is what it is but that appears to be wrong (again). yet following the same addressing patterns on other T42 calibrations yeilds tables that look ok :confused:
We'll thanks for trying :) I'll try using 2 different versions of EFI Live to make it work...
Oh, I haven't thrown in the towel, just means back to the drawing board.
Any 3-4 shift pressure update's? :):):)
OOps Sema.....
