Any idea if we will have support, or possible do, for the Bosch Motronic MED9 controller? It is used to operate the 3.6L V6 VVT.
Howard
Howard
No plans to offer support for that one. the 'D' in the MED means it is for the direct injection motor.
I would recommend supporting that controller, the GM name is E69-4 and it not only controls the 3.6L LLT currently in the Cadillac it will also be found in the base G8 as well as the base Camaro so there will be a TON of them out there :)
That was exactly my point! I have some big projects coming up with the 2010 Camaro and believe that controller will be operating the 3.6L DI motor in the 6 banger. Our primary car is the LS3 powered SS but the 6 will be a player in the performance market as well.
If I am not mistaken, isn't that controller in the caddy with the same processor?
Howard
From what I have heard from some birdies, the E38 can handle the direct injection and VVT on that motor. I guess we'll see!
Howard
I doubt it, DI requires injector drivers a little more complex than the E38 has.
We get ECM support requests that cover Tata's to 2010 V6 Camaro's. SEMA gives us a great opportunity to get a feel for what the market is looking for based on visitors questions and looking around.
Our 2009 plans are loosely mapped out and at this stage DI V6's are not on the map.
