Public pre-release is now available. See here for further details. https://forum.efilive.com/showthread.php?t=25094
Cheers
Cindy
Cheers
Cindy
Awesome
Is emissions delete not supported for international customers?
iirc not in the first release. soon though
Haven't tried it yet, and maybe I should have, but does flashing the ECM with EFI over-right the current TCM or trans values? Or are they left untouched during a cal?
I think you can only full flash the Cummins PCM and because its a PCM and not an ecm with a separate tcm I would say yes the trans tuning if you have it will be overwritten.
BigCE is correct, all Cummins ECM's must be full flashed every time, there is nothing we can do about that as that is how the factory designed their flash procedure to work.
Thanks for the info!
I know on the 2013+ trucks there has been various updated flashes for the radios and other functions, how is this handled in the ECM and what restrictions will be in place for people who have modified files in their truck? Is is simply updates based new OS's or is there more to it?
