Yes, that's a little bit on the "far-away" side of way too much.Quote:
Yeah, what Joe said. :nixweiss:Quote:
Originally Posted by joecar
Or re-phrased, you don't publicly release our format that you've already hacked, and we won't publicly release your format that we've already hacked.
Any news on this yet Blacky?Quote:
Originally Posted by 5.7ute
Yeah...that help out immensely Mick.
Transient fuelling!
time to bump this thread.
for RTACS,
i would like to be able to set the update frequency per table
instead of having a general setting.
also i am wondering if it would be possible to make a COS
for GEN3 (fbody/ybody) that could work with 58X reluctor.
is it possible to speed up the loading of logged data?
large log files take an eternity to filter/load.
Yes, currently (in V7) it is all done with disk buffers (long story - don't ask). V8 uses in memory buffers which is orders of magnitude faster.
For a comparison, the V7 re-plot of 50,000 frames can take 5-10 seconds. On the same machine, a re-plot in V8 of 50,000 frames is less than 1/10th of a second.
Since the advent of CAN or LAN it's getting harder to swap an E38, E67, or even an E40 into an old "junk" without using aftermarket guages and bypass the A/C circuit.
I notice on GM's performance controller they have an oil and alternator light, not sure about cruise and A/C turn on signal.
One thing I suppose we can do is find the O.S. of their performance controller and have it flashed in.
Thanks for listening, you guys rock!
John
How about defining/adjusting "hot mode" tables for T42,43?
Also T43 missing tables for keeping Tap up/ Tap down "in gear"...NO overide.
Thanks guys, I know this takes time!
Cheers, John
