No problem on th eEQ Ratio. I can just make it "F2" to toggle Lambda/EQ.Quote:
Alright ! :jump:Quote:
Originally Posted by Blacky
Will you be able to initiate an LC-1 free air calibration from V2...?
is it not just as easy to use logworks? Or did you go and splice that wire already? ;)Quote:
Hey, if it can be done with V2 why bother connecting LogWorks... ;)
And that will give me an excuse to slice up a perfectly good wire... :cheers:
You need a null modem, like this: http://www.bb-elec.com/product.asp?sku=9PMMNMQuote:
Or this one for $3.00 or so, http://www.trianglecables.com/202671-mm.html
But at $20 each it's not a very cost effective solution.
Ira
LM Programmer , firmware updates !Quote:
Will this release include more PIDs such as Desired/Actual Fuel rail pressure?Quote:
I have two cables:rockon:Quote:
Originally Posted by tunedbyGM
Yes, FlashScan can do that already :)Quote:
It shows "Free air Calibrate" on the screen while calibration is in progress.
