That's all well and good but what to do come emissions time here in Georgia? I don't think a MAFless C5 designed to run a MAF will pass.Quote:
It might pass as long as you do not have any codes.Quote:
Originally Posted by Patches
Bill
:D
Do you have to pass a visual inspection? If so that might be a problem. Otherwise, send me copy of your tune ([email protected]).Quote:
The latest verion of the AutoVE doc can be aquired here http://www.efilive.com/doc/index.html
Nice format.Quote:
Bill
GA does not have a visual inspection, just emissions.Quote:
Bill
Correct - no visual. But they do the OBDII query and I would imagine a MAF shut off in the PCM would raise a flag on their computer. I have yet to hear from any MAFless owner in an OBDII emissions state claim to pass. I passed my normal emissions test last March but I need to know with sufficient time in case I need to pop the MAF back on and complete adequate driving cycles to satisfy the tester.
TAQ, I'll send you a copy of my tune this morning. TIA.
Btw, awesome AutoVE tutorial. The new format looks great. Thanks for taking the time to create that.
Ed
Gotta thank Blacky and GPMX - they took on the challenge of getting into the "Live" format!
That looks good except when I print it (HP 4200dn), the top of every page is chopped. For example, on page 1 the top 25% of the header, "EFILive AutoVE Tutorial ..." is missing. I suspect there might have been a setup problem when the .doc was converted to pdf.Quote:
hmmmm.... did you save the doc to your PC before you tried to print it?
(just trying to duplicate the problem)
Edit:
I've tried a few different scenarios and couldn't duplicate the problem.
Just to eliminate the obvious, are your margins set right? Papersize?
