Thanks for sharing.
Thanks for sharing.
Is this still a necessary mod? Why cant we plug into the Serial TX port like on the LC-1?
I think they now have a serial port... let me research this.
Thanks Joe. My LC-1 decided to quit, and I replaced it with the PLX. I'm afraid I should have done a little more research.
Wow this thread is a flashback!
Looking at the new SM-AFR and M-300 they still run the old TTL level serial chaining so would need a TTL to Serial converter still to push the output levels up to 12v RS232
I ordered one. Thanks for the confirmation.
Look at callout # 5 under Technical Specs:
Wideband-O2-Air-Fuel-Ratio-Sensor-Module-p/897346002726
It does have serial output, but it's not compatible with EFI Live.
I tried to get it to work, but couldn't get it operational with the serial port. Analog works fine. I ordered the RS-232 TTL converter. It was only $4 bucks, and if I can't get it working that way, I'll just use the analog inputs.
FYI this is the latest version of the PLX SM-AFR, GEN 4.
