BBL for P12 still says need to disable HOS2II , invalid PID .
I did the auto update on this latest release. I did not plug my v2 in and do anything since doing the update. Is there something I need to do to update my v2?
I try to log and my v2 can view the lm1 wideband but not while logging or scanning. it does not show on pid list since first time configureing my 8.1.
The last 2 updates does not show my wideband on the v2. I finally got my flash scan to show all the pids and now its not recording them for wideband in bbl.
here is a log of what is showing on my v2
Final got around to update my V2 to all the current crap. Ever since I did the update, I am having issues with the scanner linking to the PCM. Its says that the cable is disconnected. Then I disconnect the cable from the V2, replug it back in and then it finds the PCM. What is the issue??
Its a real pain in the ass. It seems like its only with the scanner. The tuning side links fine.
Howard
After performing the updates to the V2, I have noticed that it takes some time for the unit to boot up upon being plugged into the computer.
Have you got the following versions running (check in the Help->About wiondow)
Scanner: V7.5.4 build 64
v7obdii.dll: V7.5.4 build 64
Tuner: V7.5.4 build 64
FlashScan firmware: V2.05.18 (Check using FlashSCan options: F4->F3->F1 then scroll down.
If you are running all those versions, can you (after the link fails),
first: save a trace file in FlashScan.
second: generate an error report in the Scan Tool software.
Send both files to me at [email protected] with a link to this thread so I can correlate the two.
Now I don't feel sooo stupid......
If you're looking for FlashScan firmware: V2.05.18, (like I was) it does not seem to be downloaded to your machine by the Online Auto Updater as part of V8....
I actually had to manually download the installer file and WHA-LAH....There is was.....
After that it installed like a snap!
Hope this helps....
Chuck CoW
Chuck,
Where did you find the file?
HT
