what i want is to be able to floor the car with the traction control and 1)doesn't wheelspin 2) doesn't bog.
Good job Ross!
I will have a look see and get back to you.
Cheers
Mick
have you had time to play with this mick?
To be honest, I don't remember writing that....:)
Had a quick look at the part numbers you supplied.
12221588 = custom op 0203005
12212156 = custom op 0202005
Either way these operating systems would be pretty close.
Need a calibration for 12221588 to work with and make sure it looks good, if this is what your after. If it is 12212156 I have plenty.
Could you confirm which operating system for me.
Cheers
Mick
Umm, Yeah I did add them into a cax that I did for Howard some time ago. I remember that I left the data in it's raw format unscaled. Funny you of all people should be asking about them as no one really caught onto what there used for.
I can have a dig around if your interested.
Cheers
Mick
When you get time that would be great. (os 12225074)
I was hoping on using these to sanity check what I have done with the IPW work. Also it will build a better filter for AutoVE as you know.
Thanks,
the other Mick
I thought the tune files were encrypted... how do you check these?
