If you're using WB02 to tune, then they aren't in your PID list.
Since it's via the analogue port you need to log EXT.AD1, then to convert that to raw logged voltage to AFR, you need to log CALC.ARF_PLX1 (PLX uses the same voltage coversion as AEM - 2v+10)
Then, log the CALC.BEN_PLX1 for you correction factor.
Also add DYNCYLAIR_DMA, TPS.
The HO2S11/2 & LONGFT1/2 are unnecessary when WB02 tuning and can free up some more PID channels to keep it under 25, same for IDC2 & INJDC2, 1 bank is ususally adequate.
Don't try to follow the tutorial for VE/MAF tuning, go to the CALC.VET Thread and use this revised procedure.
2 Attachment(s)
Now i got this after trying to hook up my analog wideband,ground and 5v from wb in a1 and still no wide band???all other scanners work , wide band pid ext a1 thats it , ground and signal to a1
update I can read through the hand help but im getting an error on the cable which i have switched out with three known good ones, SENT TO SUPPORT sorry im just having a hard time using two tools and learning efi from step one
cant log on lap top no sd car sorry joe car , my venture seems endless cant even get wb02 to work and my roadrunner just showed up arrrrrrrrrrrrrrhhhhhhhh and all of the tutorial and liks are out of date such as tac cables
Are you serious...?
SD card is less than $5 for a name brand.
You can temporarily bring your laptop to to your car in your driveway, and log like that.
If you have not gotten laptop working then how are you going to use the RR...?
When you say the tutorial is out of date, did you goto the Calc.VET thread and look at post #1 (recently updated)...?
There are threads on how to assemble and/or fabricate your own wideband serial comms cable.
Come on, get it going :) (you're otherwise missing out)
sorry joe , I may have missed one , and i do have an sd card, laptop wont log data have to use scan tool , otherwise serious ??? why doesnt someone get rid of the out of date stuff , im trying but its hard when your used to another tool serious???????????????? and as far as the wideband stuff , it should not be that hard , i have one wire to hpt
and remember i have stated in my first reply thread #1 DECIDING T TO BUY i know nothing abot this tool ,but am willing to lean with help
no worries, we'll get you going...
(I'm trying to update all the stuff... the Calc.VET thread post #1 is being updated)
You could wire your wideband to one of the analog inputs on V2... but the serial comms interface is much better, you should try to get this going if you can...
which wideband did you say you have...?
aem-34100 , thanks dude you guys are awesome due to the problems with the interface i have no ability to do any wb logs sorry waiting on a reply from support
